Hi Guys,
I have an old union carbide UCC 305 tig set that used to work perfectly ok. It's been in storage in an old barn for the past four years and not been used, although it has been kept dry. I've just wheeled it out and taken it into the workshop to see if I can get it going again. It switches on ok but I'm having trouble getting it to start welding.
With it set to DC in about the middle of it's range I can weld a piece of 1/8" flat mild steel. However the only way I can get it to start an arc is by using it more like an arc welder where you strike up the electrode on the job. If I try this with it set to AC for aluminium the eletrode just sticks to the plate or just sparks a bit. It's almost as if it's down on power but it still does this even if I turn it right up.
I've not got a great deal of knowledge regarding how welders work, just know how to use one. Has any body got a rough guess at what might be causing the problem. Or suggest a good place to start looking at.
We used to have an old machine at a place I worked which did this if the leads were coiled up.
