Surely every receiver under the sun has a HAZ on it, from bosses being welded on, the seam of the cylinder and the end seams.
Is there a HAZ on the weld shown @2:48 showing a possible repair? Paint looks burnt.
Have you forgotten to include whatever point you're making in that last post?
so is everyone going out to get there tanks tested along with all the home made blasting pots made from callor gas bottles and the cheap thin bought pots?? i think notHeat tint colours and a HAZ are two different things, can't see the later without etching a sample to highlight the microstructure [/pedantic]
I thought the point was obvious... typically pressure vessels are painted after they've been welded together by weldors that are following a WPS they've qualified to and then been subjected to NDT & hydraulically tested. Burnt paint around a weld suggests that a fitting may have been snotted in by some numpty that doesn't have a clue what they're doing, what NDT is (or thinks a miss spelling of BFH) etc
Here's another one http://www.cdc.gov/niosh/face/stateface/ca/05ca010.html fortunatly it was investigated properly and they found the cause instead of claiming it was ****** based on pumping up a crimped oil can to 50psi
As for the static, when compressors start coming with an Earth strap I will worry about a static explosion, until then I think I will soldier on in ignorance.
