Last i got was yellow)
euro dye or solvent (yellow) fill in your own choice of colourAccording to Wiki, the yellow dye will go red if you add acid, it means it can be detected even if it's been massively diluted with normal fuel.
you trying to give him a heart attack at 50 quid per gallon. ;Put some "Royal Purple" oil in to it
Easy to see & probably the best lube on the market
Its not that bad & you only do it once "unless it ****** out like mine"you trying to give him a heart attack at 50 quid per gallon. ;
Mine does as well but I was thinking of young maker.....50 quid spent 9n oil= heart failure.lolIts not that bad & you only do it once "unless it ****** out like mine"
