eLuSiVeMiTe
I cheat 15 mins in the microwave then 30 in the ovenWhy not, best mash is done with a baked potato
Although it does takes ages
To save the time looking up your old beasts width, do me a favour and measure your existing please. I will look early in the morrow for you. Cheers. Matt
We’ve just had a neff induction one installed. Apparently there’s a worldwide shortage on one of the components so delivery times are extended. I think it needed 30A from memory too - was surprised at the size of the load.
rethink and a 6mm cable installed on a new circit did not stop at that had to have new tails to the fuse board as well worth cheaking the tailsthats wot the electrician said about his bill.....Bigger is always better
Hi Parm,
Just the size of the current unit.
First one I looked at, T48PD23X0, is in stock at UK distribution depot. Would take approx 5 days normally to be in my hands
T58FT20 is in stock. This is one of the models with the twistpad rotary encoder.
Hi Parm,
Have a look on the Neff website linked below at the following models:
https://www.neff-home.com/uk/productlist/hobs/induction-hobs
T58UD20X0 803mm wide
T58FD20X0 802mm wide
T48PD23X0 792mm wide
T58UB10X0 802mm wide
That should cover all the models large enough to cover your existing hole, without the twistpad controller ( that costs extra ).
If any of the above works for you PM me your number and I will give you more details on costs etc.
I think you are about a two hour drive from here.
Cheers
Matt
