seems quite a few people on here have played with offgrid power solutions, and a friend current has some quite big offgrid issues. there isn't much avalible in the way of £'s but there is some, and whatever clutter i have hanging about can be thrown into the mix.
got 4x 12v 200HA telecom batterys to potential play with. i have got a few 235w solar pannels that can be chucked into the mix to help top things up but i dought they'll be enough. so it'll be rocking a genorator.
after recomendations for inverters and chargers ect and ideas in general to tryed and tested soultions that can be inplimented on a budget. unfortunatly batterys look like they are going to be a nessary PITA.
got a few small enignes, genorators and marine alternators kicking about that may be of use.
an idea thats kicking about atm
use a UPS type inverter linked into batterys setup as 400 AH @ 24v , feed it on a passthrough with a high ish output petrol genorator ( it's a chonda altho it works well i no longer have any use for it ) to run the relativly high power stuff ( tho this stuff chould proably go stand allone on that genny genny )
4 solar pannels > budget charge controller > batterys
problem with batterys seems to be you need to charge them at relativly low power for a long time, so i thought i chould pull the alternator off that old AC1 ive got and stuff a 24v alternator on it to charge the batterys.
any sugestions on how i'd go about charging gel or AGM batterys with a 24 marine alternator without knackering the lot, but if i can do this i chould easly make the AC1 quite quiet so it chould run though a lare chunk of the day steadly cargeing the batterys
