pedrobedro
Man at Matalan
- CX near Chesterfield
Do they make one that you can fit a chuck on the end so I can do away with the drill as well ?
I'm going to buy 2 sets and screw all 6 adapters together, then I'll be able to cut stuff on the ground without stooping down
Confession time! Just bought a set of three, who else has ?
Bob
Im assuming you are planning a wobble grinder?
Wouldn’t the guard be spinning as well?I can see a use. A guard at the bottom wouldn't go amis though
I've got a lathe, I will make my ownI reckon I could make one around a metre long for those really awkward jobs.....
I like your thinking, for getting into those really tight 'around the corner' spaces!!Probably worth including a UJ in the shaft?![]()
I'm assuming your joking rightWouldn’t the guard be spinning as well?![]()
Fit extension. Slide guard down extension and secure as normal. Then fit disk. Would also mean you could hold the shaft to stabilise.
Bob
We’ll send a forum rep to your funeral, might even have a whip-round for some flowers
I was thinking of welding a guard to the bottom of the spinning shaft……I'm assuming your joking right
Did consider that. Would help stop wobble.You could also add a shaft support bearing into the guard extension.
Bob
So essentially it's a die grinder with a cut off wheel on it.You could also add a shaft support bearing into the guard extension.
Bob
Don't get carried away! We only really need first dibs for the shed clearancesWe’ll send a forum rep to your funeral, might even have a whip-round for some flowers
