Hi all I've been a lurker for to long time so its time to come out
Now before I get started on the "PROBLEM" with my very very old migmate 100,
I purchased the welder before SIP became printed over everything "migmate",
and until recently has given many happy hours of spotty left forearm syndrome
trouble free welding.
I dont have issues with wire feed as many have even with the 5kg reel on,my welder has the adjustment pot (1k) through the front lefthand side of the machine which passes through a piece of aluminium heatsink and out the casing.
The quite large heatsink also attaches to and cools the 3 pin rectifier.
On a couple of occasions recently while working on my very rusty 1978 vw bay window I have had the welder inside the van to keep it dry or out of the sun. As one of its little plastic feet is missing it has grounded the machine and caused a short on the pcb,which without any problem I have repaired and had running again within ten minutes (and a cup of tea
Now for the comedy moment just needs a bit of imagination,
Now my dillema is I dropped the torch on the welder which landed exactly on the trigger, as I dropped it knee jerk reaction made me grab for it in doing so I knocked the earth clamp of the piece I was working on and landed on the welder torch tip touched earth clamp and FLASH and POOF is all I can describe it as.The combination as you would expect caused my welder to try and weld itself (not that it needed welding).After blowing the wisps of smoke from the vent holes in the machine I went indoors and flicked the main trip switch back on in the leccy cupboard. I pulled the side off the welder expecting to see complete meltdown, but no all it has done is burn out 2 lines on the pcb and taken out the TIP 35C rectifier,oh and broken the wire feed adjustment rod off on the outside.
When I replaced it some time ago I did'nt cut the 2 and a quarter inch or 56mm plastic bit off cos it made it easier to turn
Now I've put in a couple of temp wires in to sort out the base of the pcb and got a new 1k feed adjustment pot from maplins, although the welder works again I cant fine control the wire feed and it was suggested the 35c rectifier is fried. But do you think I can find the rectifier not on your nelly.
Looks like I will have to order online, does anyone reccomend anyone that I could phone and order this £2.00 part from.
I know what your all saying why did'nt wotwot just ask where to get the rectifier from, that would be too easy for you peeps to say GOOGLE it and would have been a boring first post.
So hello
all keep up the great forum I hope someone can advise me where to get the rectifier from.
.Now before I get started on the "PROBLEM" with my very very old migmate 100,
trouble free welding.I dont have issues with wire feed as many have even with the 5kg reel on,my welder has the adjustment pot (1k) through the front lefthand side of the machine which passes through a piece of aluminium heatsink and out the casing.
.Now I've put in a couple of temp wires in to sort out the base of the pcb and got a new 1k feed adjustment pot from maplins, although the welder works again I cant fine control the wire feed and it was suggested the 35c rectifier is fried. But do you think I can find the rectifier not on your nelly.
So hello
. A bargan at £3.49 which includes postage.
the welder is up and running like a dream
