madkayaker
Pro sparkey Pro Welder
yes if you register with a "Competent persons scheme" or through the local council. If you have an NVQ and Technical certificate in electrical you would probably be able to get full scope.
We're already no longer allowed to fit our own replacement windows and doors without having them inspected and certified.Who knows where the legislation will strike next
tell me about it if i fir windows for a company i work for no worrys, yet if i do a private job i can get a slap on the wrist. you can pay the council to have them tested and certified but it cost's £££.We're already no longer allowed to fit our own replacement windows and doors without having them inspected and certified.![]()
) and as for windows, well I'm aghast that you can't do your own now, I didn't know that.It's a pity that those that are supposed to be Part P "qualified" aren't legally held to account in some way.
That would stop anyone from blackmailing the clueless into paying extortionate amounts of money for simple electrical system additions that the law says need to be checked and certified.
Sure - bad and irresponsible workmanship, carried out by the "that'll do" brigade nust be stamped out, but the law should not give to#sers the opportunity of ripping punters off.
how long is the run. The cable should be 900mm down but if there is no risk of mechanical damage just under the grass is fine?
.Google IDRATeK, its a lv hvac for houses system, although you do have to run the control networks in at first fix stage for it to be truly neat. Im hoping it will knock the abortion that is X10 powerline hvac into oblivion so I never have to work on another single badly designed underspec'd piece of rubish made by X10.inc again. We had a whole house x10 install in the last place,a nd Im running idratek in this one.Personally I've always wanted to do away with the usual domestic distribution board and design something along industrial lines so you could have low-voltage control at light switches etc rather than 240 as it is now. Another benefit is that it's dead easy to add PC control so you can have lights, curtains etc. controlled by a program so you can simulate activity in the home when you're out, reduce electrical consumption etc etc. In industry it's all tied in to the HVAC and you have an 'Environmental Control' system. I know it CAN be done in houses but the existing format doesn't lend itself as easily.
