heldtogetherwithblutack
- Newton Solney
Gifted 185A no name mig, works as it should, however, the tip sits so far back in the shroud the wire curls almost to the shroud opening. Tips are M5 thread and searching for a longer replacement only turns up the fitted one at 18mm long whereas I guess the tip needs to be about 25mm long to fall just short of the shroud end.
Anyone know of a suitable replacement part or source?
Failing that, an option would be to cut down the shroud and swage the end a little, a right ball ache, as it came with 4 as well as a spot welding one.
