I'm fairly new to MIG welding and am hoping for some advice on a problem I have. When I 'weld' (ha ha) the wire comes out the tip, arcs then breaks off. Not so much welding but a fireworks display. When this happens the wire usually sticks to the tip and I have to release it with pliers.
My welder is a Draper MIG that I bought 2nd hand a couple of years ago. It worked ok then and after emmigrating it sat in my garage for 2 years. I tried it last night and the 1st weld was ok. Subsequent welds were as described above.
Any help or advice gratefully received!! Thanks guys....
- I'm using (new) argon/CO2 which I know is working.
- The wire feeds smoothly when not arcing.
- The tip is new (0.8mm).
- Metal to be welded has been flapwheeled and is spotlessly clean.
- I have a good earth on the workpiece.
- The wire is 2+ years old and I'm thinking it may be the problem. Could it be that the 1st weld was ok as it was the wire shrouded by the liner?
