Why not get a Clarke 90 if its cheap and get a cheap Chinese arc invertor?? That way you can weld your thicker pieces with the arc welder and thin stuff with the mig
Or just spend more and get the 160
The 145 is one of the budget machines I think. See my previous post about them. The 160 is a useful bit of kit, I've got the 160tm. The 160en is about the biggest you can run off a 13a plug, may blow the odd fuse if used on full chat.Thankyou everyone for the great help and funny debate haha and all of this information is great help! I have re-decided to get a Clarke MIG 145 or 160en (or higher) as they can be converted to use conventional gas bottles, which by the sounds of things is needed! so have decided on the welder now just need to work out this whole generator power business.
I'm the same, mainly bike stuff, bought a 160en years ago and still have it. Now iv a Tig, mig, arc, and a lathe. Its a disease lol
Edit. Just looked & the 145, 180 &196 are the budget ones, Chinese I think. The budget ones can be identified by the funny curved handle out of the front & the price.
If run on full power it will just about run off a 13a plug, as I said, it may blow a fuse or two. This would make it somewhere around 3000-3500 watts I would guess. You would need a generator at least twice this to run it successfully. I've never tried running off a genny, but I understand the sudden loading when you pull the trigger will overload the genny as it cannot react quick enough & cause it to "bog down" the sudden volt drop can damage both the genny & the welder. As I said, I've not tried to run one, but someone who knows more than me will be along in a minute.
Its good on really thin stuff, car panels(but you need gas for this) and you would just about get away with 4mm. I converted mine to use a spool gun for aluminum too. Iv had absolutely no problems with it.
Now there is an option for cheap Chinese MIGs like tigmig sell, and personally I think they are great and much better than the Clarke range, but quality control can be a problem and you might not have any come back if its faulty
