Hi mate welcome, If its mig welding then a light argon co2 mix (5% argon) will be good for both .cheers..pete.
I think you meant light CO2 mixture (5% CO2).Hi mate welcome, If its mig welding then a light argon co2 mix (5% argon) will be good for both .cheers..pete.
I'm using Argoshield Universal as it was recommended to me by BOC as I weld 3-6mm usually, however I've since spoken to a chap at a local ironworks and they say they only use Argoshield Light regardless of the thickness.
What do you reckon, should I switch to the Light when my bottle runs out? (Could at least use the mig on s/less then)
Argoshield Universal is designed for 5-10mm. Light is for up to 5-6mm, basically car body / chassis work.
5-6mm bodywork what tank u drivin
5-6mm bodywork !!.... yeah I drive a Chieftan....lol..
Light if for UP TO 5-6mm.....
