angellonewolf
- bristol england
i know we have a few people on here that use 2 stroke tools for a living so im hoping i can ask a question
at work we had a husky big chain saw its been well used and lost it compression so a new piston rings and cylinder was installed (not by me) was used after the rebuild it run but starting to get hard to start with in a very short time and was dumped in the shed
i as some on here know i play with 2 stroke just for fun so took it home to have a play
cleaned the carb (was nothing wrong with it)throw fuel in the bore nothing bit of smoke now and again but not even tryed to run
so looked it over and thought just cheak the nuts torque on the bolts holding the bore on 1 was not tight 1 i could not even get my allen key in looked at it with a camera and found the head broken off shearded off (i dont think it would be like this when built) so i had to remove the head to get the snaped bolt out
on lifting the cylander there where large scrach marks all over the piston
any ideas what could have caused this ?
the parts where cheapy stuff so i was told
and the 2nd part im most way through a sthil piston and rings replacment and want to know what you do after install more oil in the fuel for the first couple tanks ?
its not as though you can take it steady for a while like breaking in a bike apart from not reving it with out load on it
only reason im asking is as im doing the piston swap want to know what i need to do to run it in or such as ive done a few pistion and ring changes but not meny as cost wise your better off buying a working 2nd hand one by the time you buy all the parts on most 2 stroke stuff (only sthil seam to beable to get cheap bits for)
