Badger1bear
If your not on fire, then your too far away
- kent
I started using it this morning and whilst welding the regulator gives off a high pitch noise, soon as I stop the noise stops. I never had an issue with this reg on the BOC cylinder. The only difference I see is BOC is vertical take off and sgs is horizontal take off, that shouldn’t make a difference should it ???
Also does anyone know if sgs do different ratios of argon mix or is it only the pic attached ?
