no point in fusing the negative on a negative earthed vehicle always the positive
Am installing a second leisure battery to the camper ,wired in parallel,to remain 12v,does it matter if the fuse is connected to + or - ? Thanks.
All true.I know you're an electrician, but I can't understand why, on a dc circuit, that should make any difference.
Current will be identical at the positive pole as it will be at the negative. Indeed the flow of electrons go from negative to positive, and it's only historical convention that states that "current" flows from positive to negative.
Again, current at the negative would be the same as at the positive. Assuming you're not shorting prior to the fuse at either pole I can't see why it would make any difference at all which pole the fuse was on.
But if the setup is negative terminal of the battery -> fuse -> chassis then when the fuse blows everything is at the same potential as the positive terminal.All true.
The problem is the entire car body is the earth. Any short from the power in your bit of bolted on equipment will earth to the body and the fuse in it's own earth lead will do not a lot. But one in the positive lead should blow, assuming its rated correctly, before things get too exciting.
To add an edit - on older, positive earth vehicles, the opposite applies.
Not sure any of my vehicles, registered 1979 through to 2016, have a fuse in either battery lead until the positive lead makes its way to the main fuse box - where each circuit is protected by a fuse. Other fuses are dotted around (especially in the Lancia!) for individual item.
Never had any hassle, so see need to re-invent the wheel, or indeed argue about it, given the explanations above.![]()
My 1963 mini is positive earth. Not hard to change them to negative but its still running with an original dynamo and I like it's originality. Always have to think a bit harder when doing anything electrical, positive being earth is just counter intuitive, to me anyway. Being a child of the 70's I remember warning stickers in car engine bays advising "Warning this vehicle is negative earth" when a few years earlier the opposite was the norm. Saw one only yesterday at a car show on a beautiful Mk1 Escort RS2000.It’s why I replied with “the live side”
Older (really old!) vehicles could be positive earth.
Perhaps I should have explained more details?
First battery is fused via feed from solar panel,then supply cable to fridge,is also fused,both on positive side.
Does that detail change anything,part of the problem is ,I just forgot how I connected them in the first place,I’m 60 now so keep forgetting.
@Barking Mat ,learnt that the hard way! In the dark at Le tranche sur mer,had to ask locals for a push,lucky it’s an easy starter.lol.
