thanks, thought it was strange that a red wire goes to the clamp, do you know if its wasy to change on this type ?
Yes, release wire feed roller tension (so it does not feed wire). Then, with meter on DC Volts, one probe on torch tip, other on work clamp. You should get 20-40 volts or so. The meter will tell you the polarity.is there anyway to test it with a multimeter ?
