1600 amps? Try a 4" nail.
No you have to inform building regs if you change the CU unless you are part of the Part P compliance scheme.
dont wurry about it even if you have done it recently .as long as its been done correctly and the gas and water or oil services have been bondedIs that even if I changed it when we moved here 13 years ago?
1600A![]()
its only the main fuse they downgrade though the actual meter will still be capable of a greater amperagei don't see what the fuss is all about, a half decent power shower pulls enough power, ok th epower factor will be a bit diffrent but really.
i know when they fitted the new meter they downgarded us from 100A to 60 A i chould in theory overload that meter without much effort, in fact i'm now wondering what it'll do if i do that to it
I would say it's probably a historical thing as much as anything, 30 years ago there was nowhere near the amount of electrical appliances that you find in today's houses.I don't understand why they fit such small supplies, is it eco mentalism or lack of grid capacity?! You see on like YouTube vids folk talking in the US about 300a main breakers on your average house?!
My neighbour complained to me about my 3hp compressor - when it kicks in it makes his lights dim in his garage where he has his model railway. It is a road of 30s semis. I know just try to make sure I only use it when he isn't in there!
ther just moaning farts. if u put a 10k shower on it will pull the voltage down depending on what time of day it is . teatimes the worst as everyone is cooking and using full loadMy neighbour complained to me about my 3hp compressor - when it kicks in it makes his lights dim in his garage where he has his model railway. It is a road of 30s semis. I know just try to make sure I only use it when he isn't in there!
probably right if you added all your usage up and divide by 24 hours, unless of course your heating is electricthe average pull of a house i remember being told was something silly low like 500w
5kva is small by todays standards even without a shower, the transformer would be flat out if they had an electric cooker and a dryer going at the same time, I bet there will be a few of those left in remote placesThere is suprising little load on some of the network,,most of the pole transformers we go to are not normally pulling over 60 amps per phase, and that is running a village! As long as we all downgrade our vacuum cleaners etc we should all be fine with the welders,lol.
On faults in the Highlands we came across a property with a 5 KVa transformer,, fancy having to have an upgrade so you could fit an electric shower,,
If its a moan about power factor, every house has at least a fridge motor running,as well as a freezer one,,the power factor will be no where near 1 so for occasionl use i wouldn't worry,, a 60 Amp fuse will take a lot more than that to blow it,,
