I need to get a flange made as per the pic below.
Thickness of plate is not critical but prob best in the 13mm to 22mm range.
Just in bog standard steel that can be migged with standard wire.
Have I got the distances between the holes / PCD right with 121mm across the center & 61mm between adjacent holes? Its the closest I could measure it using a tape.
The 160mm is also not critical & can be smaller or larger as long as its got enough "meat" around the holes.
Can any one make me one ASAP & post?
If not rough prices for getting a local place to make one up.
Cheers
Justme
Cheers
Justme
