Jaeger_S2k
- Highfurlong, Blackpool. Lancashire
The hunt (although more of a drag net) for a 5hp / 4Kw single phase motor continues.
At the same time looking at Inverters, it's quite an economical route. 3 phase motors are much cheaper than single and with the inverter still work out quite reasonable.
But I'm not 'Fully standing under' the 3 phase supply and motor voltage.
This has caused much thinking and have a few questions I can't answer no matter how I search.
What are the options.
What are the standard 3 ph variations in the UK?
Input - 240 v What are the outputs 3ph 240, 3ph 380, 3ph 415v?
Then there's talk of 'if you don't have dual voltage, star and delta (head hurting again) then you'll need and inverter that boosts the voltage to 415v'
So to me that's means, 2 phase motors (that are dual voltage) run 240 or 415, so would a US inverter work on that?
Are there motors that are 3ph 240? Or am I getting confused by the US.
