hi my name is kev and i found this site while looking for tips on how to mig weld with no gas. i havent welded before and i am looking for tips on how to start eg what speed of the wire and what setting to use. my mig welder is wolfweld 140 turbo fan cooled combination gas/no gas. it said on the manual that it is set for electric use but as i went through manual it said i had to change thickness of wire from 0.6/0.8mm to 0.9mm wire flux and also change tensioner to 0.9mm. i did so but when i tried it out on scrap metal it just kept spitting. it also said about changing over the + & -wires but the diagram does not match the layout of my machine any suggestions on how to sort this problem. once i get the hang of it i will be welding parts of a old snack trailer which has split joints and has holes due to heavy rust which i will put pictures of it on soon. i have grinded and cut most of the rust away and covered with no.1 rust buster for now till i can weld.
all suggestion welcome and need asap
thanks
kev.
thanks
kev.
to the forum
