Hiya all I'm new to this forum my name's Scott. I own a SwitZer sz mig 100 I've tryed all the setting adjusted the wire seed and it just keeps putting holes in the metal I'm trying to repair car body panels. It just seem to be putting out touch power anyome know what I can do to fix this thanks inadvance.
Hi Scott, and welcome to the forum from another Scott What thickness is it you're trying to weld, and what amps have you got set on the welder? You're going to want to get it as low as you can, 30A or lower. Do you have much welding experience? Reason I ask is that starting on thin car panels ain't the best way to pick up the experience - you'd be better practising on thicker metal first,, then working your way down. From the picture it kind of looks like you're trying to "plug weld" holes, rather than weld in a patch - is that what you're trying to do? Putting in a patch should be more straightforward - try "spot-welding" it initially, just doing quick blasts to weld spots every few centimetres, rather than weld an entire seam.
Hi Scott and welcome. Never heard from of the machine but it looks similar to the Clarke ones. Try Min, 1 and wire speed around 5. The picture you posted looks like it has a coating on it which needs removing to bare metal. Try on some scraps of metal first. It’s easier to weld thicker metal than thin so try something thicker to get started with and then thinner stuff. You will find with thin, once you start to weld it distorts due to the heat. You need to just do small welds or better still spot welds, allow it to cool and then repeat.
Yes, too much power is the problem. From the specifications: "Output Current Range: 50-100A". The "low" setting of 50 Amps is about double the power that you would need for thin panels. In addition, the electrical symbol on the data plate shows that the machine is just a transformer. There is no inductor, and no rectifier, so the output is AC rather than the expected DC that would be usual for a decent MIG welder. Gasless wire tends to weld hot, spattery, and smoky, and running it on 50 Amps AC, there's no chance of welding thin panels. If you are into electronics you could fit a rectifier, inductor, capacitors, even an input power controller ( "light dimmer" ), but other than that I'm afraid that the only answer would be to send it back ( if possible ), and buy a more suitable machine.
Wow that escalated quickly, in general it is always appreciated if you answer the people who try to help you.
All these Chinese MIGs are the same, unfit for purpose. Some have an even worse output range, 60 - 90 Amps. The new Sealey Mightymig 100 is also included, you'd hope they'd know better? For that budget you might find a used and probably neglected blue Clarke, 90 to 150 Amp. The problem if you're new to MIG, is that you won't know if it's working properly.
To be able to suggest how to proceed, it would be useful if you could explain more about what you are trying to do. - is this a one-off project, such as fixing a rusty car for MOT? If so, some pictures showing the extent of the problem would help. - are you fitting new panels, or covering holes with self-made patches? As well as the price of the welder, you need to factor in the cost of materials ( panels, steel, paint, underseal, and especially shielding gas ), metal-working tools, and PPE. The cost of gas can be avoided by using gasless, flux-core wire, but most people find this process difficult and messy, especially for a beginner on thin sheet metal in hard-to-access areas.
Nothing has escalated my friend I do appreciate all the help everyone gives me I think you have took what I said and took it the wrong way
Sorry my mistake I should of been more specific it's to weld a car for its mot I will upload some photos tomorrow I'm trying to weld two complete sills and rear aches
Huh? What escalated quickly I don't see any problems with the original query, responses, and the OP's follow-up
I don’t think the post from Guzrik was meant in a adverse way, if you read it, it could be taken either way, compliment or not.
Fitting the complete sills will make the job easier. You can remove the existing ones by using a spot weld drill, and then plug weld the new panels on. The MOT rules allow this ( as opposed to the otherwise mandatory seam welding ) when complete panels are being replaced.
You asked for help and got it, in the best way, but in stead of trying what was suggested you threw in the towel and send it back. At that time I felt a bit dissapointed, now I see my reaction was exaggerated and blunt. I am sorry. Hope you can find a better welder, I would suggest one like mine, but don't think they were sold in the UK. It is a Concept mig 180/2 turbo, have it for 25 years and happy with it.
