hatefull old JCB wouldn't go for me today, after about half an hour banging head against wall useing the start charger, i realised i was being very very dull.
when the hell am i running the engine drive set to run a 200 amp start charger of the ancillary output ........ when the welder has a constant voltage setting and best part of 600 amps.
set to 15 volts, connect welding leads to battery and flick the switch. sounds like it about to start but not quite so turn the dial a bit more and a bit more and a bit more.
probaly reallys shouldn't do that but was quite inpressed by how brutaly effective it was, also drew my attention to a sub optimal connection on the battery isolator
