DAPPH
as dyslexik as I'm daft
Not so bad if used on tin plate screwed to a fixed board and used on very slow gentle feed . Could also be used as a low sped low feed fly cutter for cast ironThis is a trepan. The pilot goes in the end of the tapered shaft held by the grub screw and the cutter goes in the flying shaft also held by a grub screw. A very handy (but potentially very dodgy) tool in equal measure.
I used a tail stock mounted fly type cutter a few months ago turning the tin plate on 20 mm marine ply backer screwed to the lathe face plate and trued up to get a round clean hole 6 inches in diameter in some 5 mm alu plate
