Can you not get them from Myford. I know they cost approx £20 each but by the time you've sourced the correct profile cutter & taken the time to make them into account is it worth the effort. If the parts were unobtainable I could understand why you would want to make them yourself.
RonA
just be more carefull. ive had my myford for 40 years and never knacked anything and all the gears are ironThe reason they are Tufnol is so they DO break when a set up error is proven. Making them from something less forgiving MAY result in damage to something else, which may not be as easily, read cheaply, repaired.
The main reason they fitted them is not as a sacrificial safety device, it's for quiet running, even more important on the super seven because of the higher spindle speeds, like B S I've had my myford over 50 yrs with no trouble & they're tufnol.The reason they are Tufnol is so they DO break when a set up error is proven. Making them from something less forgiving MAY result in damage to something else, which may not be as easily, read cheaply, repaired.
If you do make your own I think you have to make them out of sheet and not rod..Thanks CRB. They are a No 4, 20DP and 14.5PA which by sheer luck I have one that I got with a batch of 'engineering tools' I won on a random eBay bid!! I am going to make some new gears from Delrin.
No you can make them from rod just fine. I have two gears in my lathe made from Delrin rod.
I think he was referring to the use of Tufnol, due to the way the laminations are done on sheet versus rod.
Yep I bought some from him and they are great. The myford ones were ****e, ten tooth broke off one still sealed in the bag!!There's a bloke on eBay selling these for about 20 quid the pair brand new. As per my other thread I had nought but issues with the ones from Myford culminating in them admitting there was an issue with the batch and refunding me with no idea when it would be sorted.ill see if I can find the eBay linky
I wonder if they were cut from rod not sheet?Myford argued with me that I was setting them wrong, until I made them go and get a tumbler arm out of stores and tell me exactly what adjustments they reckoned I could make
