Looking at the first pic, the shaft that holds the pinion looks to be in a collar that does not exit centrally from whatever housing is supporting it. Perhaps that collar is an eccentric adjuster for the gear's backlash?
You have great eyesight
I hadn't really noticed before, so I have just been in the shed to investigate. Indeed it does look like that kind of system. It seems that it may be the outer shaft housing that rotates. I dont know for sure until I look deeper, but it will explain the reason for the damage, and make my life easier when fitting new gears.
I had visons of pinning the gears to the shafts pretty close to where they should be, then shimming them up to the required tolorance.
I shall learn a lot from this build I reckon.
Pete, I followed your thread you posted on another forum regarding scraping your Warco. It was a good read. I only hope I don't need to do any scraping on my machine. I know at least the saddle gib is worn pretty badly, but the knee gib 'looks' ok.
It was indeed a good spot on the eccentric shaft!
Now where will I find the milling machine scraping thread please? Are we allowed to post links to other forums on here? If not a few gentle hints may help.
Edit: Found it at BBS Home shop machinist. Havent looked on there for a while.
Now painting on the other hand...one problem with that, what colour to choose![]()
). My personal favourites/choices are either Brunswick Green or Wine Red. I use Black/Blue, (Schwarzblau), for nondescript bits and pieces, then the green or red where I think it suits best.
I have also ordered a tin of paint![]()
)It'll finish with a dull grey colour but it'll be very hard wearing, as you'd expect from floor paint. I've been working on my lathe for weeks now wheeling it about the workshop on casters, spinning it round to get access to different areas and catching the benches with it and it's picked up very few chips.
I would take that housing and bore it through straight, then add a couple of sleeves to hold the bearings. You could add in a little eccentricity so you have a 3-position backlast adjustment.
). I think at this point in time, I may put it on a future project list and concentrate getting the mill to a working state
. Today I dsmantled it into bits and it's still a 2 person job to lift!
Nice mill Kev, similar size to the 6x26 I have at home...
It does look to be in that class. Sort of an inbetweeny between an industrial and a hobby machine. Perfect size for a large shed/small workshop.
