Just get someone to chuck it up in a lathe and skim the face, you`d want to do that anyway to ensure you had a true and flat surfacehow many of those wheels from trailor stands are going to have nasty flat spots and damage ?
Depends on what you want to do mate, if you need to make a patch panel with a simple curve or a compound curve then the E-Wheel is the perfect tool to do it quick and easy
Would these work?
http://www.ebay.co.uk/itm/200mm-Cas..._Handling_ET&hash=item3f14075a16#ht_623wt_922
They have a poly tyre which could be cut off if no use. The poly might be good for softer materials though.
