oceanobsession
Im going to have a go at a dive bottle rack in 316 stainless steel. i can buy
the tube and bends local you can get 45 and 90 all diameters of tube i would have to
tig the pipes together using the back perging method i have a lathe at home
so i could use about 35mm diameter tube say 3 mm thick this would go through the chuck so i can turn them all to perfect size i would need mor help
with the back perging method but ive seen it done and the weld berly visable
would you tee into your reg with another pipe i know you tape off the ends of the pipe the feed the tube into the tape but how much argon do you have going into the pipe also what size tungstone and amperage would i use for best results just fusing together i have put a pic so yopu get an idea of what im attempting to do
cheers oceanobsession
