J johnreid New Member Messages 1 Location Fife Sep 23, 2021 #1 Murex 353 transmig voltage help - suspect low welding voltage- on maximum getting 28 volts. What should voltage be? Can anyone advise? Thanks
Munkul Jack of some trades, Master of none Messages 7,370 Location Cumbria Sep 23, 2021 #2 OCV (Open Circuit Voltage) should be 40v, under load it will vary a bit. Looking at the manual the setting range peaks at 33 volts. If it's only showing 28v OCV then there's something wrong...
Spark plug Member Messages 4,062 Location Durham, England Sep 23, 2021 #3 I’ve just checked my 353, on the highest setting the screen reads 45V OCV and measures 48V OCV with the multimeter at the torch. I’ve had similar problems in the past caused by the one of the voltage selector switches failing.
E eddie49 Member Messages 4,093 Location Reading, Berkshire Sep 24, 2021 #4 The fault could also be due to loss of a phase in the output, caused by a burnt or corroded connection or an open-circuit diode in the bridge rectifier.
