Rail_Head
Have come across this stuff on flea-bay:
item No.: 150037028841
Its made by a company called Action Can (located in St Helens)
The description says “
AS-90 Is an advanced, non-flammable, anti-spatter wire lubricant and corrosion protector. It assists the smooth flow of welding wire to the welding torch”
Has anyone used this for its ‘wire lubricant & corrosion protection properties???
Am I assuming it means you can coat welding wire on the reel to help prevent corrosion?? Seems too good to be true!!
Don’t fancy coating a 5kg reel to see how it ends up?? So, any one used it?? Any comments??
If not, I may get one & use it when there is only a bit left on the reel to see how it goes ??
Cheers
Cheers
(I say England cause as far as I'm concerned any English club in the European cup final is representing England). Do get the odd faulty tin Hitachi but just sling them back at the supplier. Clean-Weld does'nt use a conventional aerosol system, instead using a bag of compressed air & I think it's that that gets disslodged in transit sometimes. Good stuff though don't you think?
