Rail_Head
Have come across this stuff on flea-bay:
item No.: 150037028841
Its made by a company called Action Can (located in St Helens)
The description says “
AS-90 Is an advanced, non-flammable, anti-spatter wire lubricant and corrosion protector. It assists the smooth flow of welding wire to the welding torch”
Has anyone used this for its ‘wire lubricant & corrosion protection properties???
Am I assuming it means you can coat welding wire on the reel to help prevent corrosion?? Seems too good to be true!!
Don’t fancy coating a 5kg reel to see how it ends up?? So, any one used it?? Any comments??
If not, I may get one & use it when there is only a bit left on the reel to see how it goes ??
Cheers
Cheers
