Motorcycle battery chargers
  1. mangocrazy
    mangocrazy Italian V-twin nutjob
    569
    Sheffield, UK
    I've had an 'interesting' couple of weeks with batteries and chargers... I'd left my old VFR750 down in the gaff in France over the winter, with the battery hooked up to an Accumate charger/tender. When I came to start it, despite the charger indicating full charge, all I got out of it was a click from the solenoid. When I hooked it up via jump leads to a fully charged car battery, it burst into life. So my conclusion was that I had a duff battery, despite what the charger was telling me.
    Get back to the UK (bike came back in the van) and the charger still tells me that the battery is fully charged, but I can't even get the clock or the dash lights to illuminate. Anyway I've pretty much decided to replace the old battery with an AGM Motobatt MB12U, but their site gives dire warnings against using conventional battery chargers to charge them. Unsurprisingly, they have a charger that's perfect for the application...
    So, my question is - what charger/tender would you recommend to charge the new generation of AGM/Gel batteries? The charger doesn't need to cope with CAN-bus, but if it did that would be a bonus.
    Thanks in advance...
  2. pedrobedro
    pedrobedro Man at Matalan
    9,411
    CX Derbyshire
    Don't leave your battery permanently connected to any charger. Plug it into a timer to come on for an hour a day if you want it to survive.
    RonA, Alan Reynolds, 8ob and 2 others like this.
  3. rtbcomp
    rtbcomp Moderator Staff Member
    18,373
    Sheffield UK
    That was my brilliant plan until I discovered that you had to push buttons to start the charger, just switching the mains on wasn't good enough.
    ajlelectronics likes this.
  4. eLuSiVeMiTe
    eLuSiVeMiTe Forum Supporter
    6,030
    Bedfordshire England
    Can't fault my ctek no button required to start so a timer would work too. Also has recond.
  5. mangocrazy
    569
    Sheffield, UK
    Any particular model?
  6. frank horton
    frank horton V twins are great but 4"s rule.........
    1,162
    manchester, UK
    depends on the batt type..theres a lot that use Lythium now which require a spec charger......
    never bothered myself, I try to buy a quality GELL batt which is basically a lead batt.......never a prob.....
    with modern vehicles, bikes and car's the comp/ecu nick's just a tiny bit of elec all the time so I always disconect for long shut downs......
    Yuasa is my fav batt and usually even after a 6 month lay off, reconect the bike will start right up.....
    or just an overnight trickle will sort it.......
    not that it matters now as I'm leaving FR but where's ur place out of interest.....
  7. carbon
    carbon Member
    990
    S. Glos. U.K
    I have a couple of Ctek chargers one is left on all the time without any issues so far. Also have a dc to dc one to charge an auxiliary battery in my van. The battery is an agm type and no issues with that either.
  8. addjunkie
    addjunkie Member
    4,745
    Northumberland. Reet oot in the sticks
    I use two different optimates, no issue at all, but batteries do die with old age. My xjr, first battery lasted 3 years, before it wouldnt hold charge, current one been in 10, but thats just jinxed that, sits on an optimate all the time, because I dont use it much.
    Our stanby generator uses the other optimate seems fine, though I run that fairly regularly.
    stuvy likes this.
  9. dobbslc
    dobbslc Member
    3,780
    Hertfordshire UK
    I second the Optimate chargers! I've had one for years on my TRX850 and FZR 400 race bike that doesn't move anymore.....:(
    It cycles the charge rate up and down then tests the battery and starts again. They are meant to be left on all the time a don't damage the battery at all. No button to push so you could put it on a timer but it's not really worth it.
    stuvy and Shox Dr like this.
  10. dobbslc
    dobbslc Member
    3,780
    Hertfordshire UK
    Here's a used one on Ebay, it says it's for AGM type batteries on the top.
    283483184455
    They do hold there prices as they are sort after.
  11. Craig-SM
    Craig-SM Member
    126
    Leeds
    I’ve had an Oxford Oximiser for a fair few years. You must leave it connected and it will trickle charge the battery until full then monitor it, if the voltage drops it will automatically start to charge it again. Mine is one of the first models but still works on Lithium batteries as well as bigger car batteries.
    Only battery that has failed on me was down to a failed rectifier on the bike that fried the battery.
    stuvy likes this.
  12. lazybones51
    lazybones51 Member
    201
    Northamptonshire, UK
    I use a Lidl battery charger for all my batteries. The Triumph has a Motobatt AGM battery fitted and the charger works fine. From what I've read an AGM battery isn't really all that different to a traditional lead acid battery, it just contains a fibreglass matting which does something with the acid? They're not a gel battery.
    dobbslc likes this.
  13. rtbcomp
    18,373
    Sheffield UK
    Mine is a "Tronic T4X" from Lidl. Cost £10 when other places were selling them for £40. Had it for ages and works well.
  14. Yes they do, I have a couple. The only irritation ( as with my C-Tek) is having to select a program every time it is turned on, so a timer is not good with it.
  15. Migmac
    Migmac Member
    2,868
    Kintyre. Scotland
    I used the Oxford optimiser, it did a good job. Started using it on my golf trolley battery until i went down the lithium route. It did keep all the batteries I had it on fully charged up.
  16. mangocrazy
    569
    Sheffield, UK
    We're down in the Languedoc - Pezenas/Beziers area.
  17. mangocrazy
    569
    Sheffield, UK
    Looks like an even split between Ctek and Optimate... I'm pretty sure that the Motobatt battery blurb is designed to scare you into buying one of their pricy charger/tender units. As people have said, AGM batteries are just an evolution of lead-acid.
    dobbslc and lazybones51 like this.
  18. earthman Member
    475
    My Optimate 3 shows a green light even on a known duff battery,...they are rubbish at telling the true health of a battery in my opinion.
  19. carbon
    carbon Member
    990
    S. Glos. U.K
    Agm batteries have a slightly higher charge voltage than conventional lead acid ones
  20. Robotstar5
    Robotstar5 Casanunda Staff Member
    17,398
    Birmingham
    I think my first Optimate failed after 15 years so I bought another, that's been fine for about 5 years now. I've left bikes plugged in for 6 months without any problems.
    stuvy likes this.
Advertisements
