I have a ts300 mosa. im running my miller 12vs suitcase/fidder of it cant seem get it going right using ferromaxx15 gas. Is the miller 12vs not compadibill with mosa ts300
I can't remember which it is you need to run your suitcase feeder but it either needs constant voltage or constant current. I almost bought a Mosa 300 but found that it didn't have the correct wiring ie: cc or cv. In the end I bought a Lincoln Ranger which works a treat
I used to used these the vs version (voltage sensing) should operate on both constant current/voltage. There should be a switch inside cv/cc make sure it's right for the power source. Have you connected the small remote lead to the return and if so is it in good condition. If this dose not have contact it won't work on any power source.
