Ill try that tomorrow.will report backBest way to be sure is try it on a diode if you have one kicking around, even a led would be fine then unsolder one end of the diodes incase somthing else in the circuit is mucking it up.
Diodes all give about 0.6 in one direction,no reading in the other
The little black ones are good,where are the power diodes?Sounds perfect on that front then.
edit.. Was that the little black ones or the big power diodes?
Ive cleaned up the boards and the linkages and now ive 65v at idle on high amps settings,but its very much ac voltage
It might be ac,no sign of big diodes anywhere.wierd as i was getting dc output the other day.
