SirDick Diodenob esquire
Need advice please . Last time I arc welded was about 30 years ago using an oil cooled welder , was hopeless then and still am . Using a Lincoln 140 amp invertor which gives a very smooth arc , easy to strike and keep going much easier to use than a buzzbox or oil cooled welder . The poles are being welded at right angles with one being ground out to be a good fit against the cross peice . The poles were originally galvanised but heavily corroded , used a grinder to take both peices down to clean mild steel and a welders clamp to get an accurate 90 degree angle. Using 2.5mm MWA E6013 sticks , tried currents between 65 and 90 amps and so far used 10 sticks for one joint which if I think should have used maybe 2 or 3 sticks at the most and its still not finished after three hours work so I will never make it as a welder but somehow I need to finish this job as its for someones birthday this friday and it still needs painting . First problem is unable to see a thing through the cheap Halfords mask and difficult to even keep the run on course on the joint but will try a Murex glass shade tommorow , may as well just close my eyes with the mask I am using today . I think I should be using bigger rods and a higher current maybe 4mm and 120 amps ? The joint is butted with no groove , is this a bad idea and would it help if I grind a channel in it ? Have read the posts on welding pipes but seems to be mainly about using TIG rather than MMA and for welders who already have a high skill level .
