roblane65
- Newcastle UK
A few welds with the 200 evo , I managed an hour on sunday in the garage although it took longer to find and clean some metal , it's loaded with lincoln 0.8 wire. Alldone on auto settings
a fillet of sorts on some 5mm ish
torch angle and travel speed need some practice ! some bead runs a lap and fillets on 2mm ish
below is the penetration on the lap and bottom bead on the reverse of above
A few other welds
I think it's clear to see at times I can't see where I'm welding and this really needs to be addressed ,
One thing I do like is when you set the thickness on auto it only displays the wire feed speed but once done a weld the display holds the parameters used amps and
volts until the trigger is pressed again . Handy if you want to take notes then tweek those settings in manual mode
thats it for now critic away please .
A few other welds
I'm in Hereford next weekend for me Mum's big birthday .................
