C Cheesie Member Messages 1,260 Location Lisburn Mar 21, 2021 #1 If a machine has the capacity to cut or fold say 2mm mild steel, how do you work out what it can cut in aluminium and st/st
C Cheesie Member Messages 1,260 Location Lisburn Mar 21, 2021 #3 Thanks brad was more thinking if there is a simple formula
S selectedgrub Member Messages 3,614 Location New Zealand Mar 21, 2021 #4 45 times the capacity of the machine over the tensile strength of the material timed by 36 Aluminum at 25kg/mm2 hardness = 45 x 36 divided by 25 = 8mm. Stainless steel at 70kg/mm2 hardness = 45 x 36 divided by 70 = 4.8mm.
C Cheesie Member Messages 1,260 Location Lisburn Mar 21, 2021 #5 Sorry I should of give more info I know how to set up pressbreaks ECT it's the likes of box pan folders and simple guilotenes with No adjustment for material thickness ECT
