Melvyn Dodridge
New Member
- England, Nottingham
Pressing the torch trigger and no wire feed. Done lots of checks. The earthing is good. Had the PCB off, the relay coil is 200 ohm, the grey box transformer is 30 ohm, the transistor TIP35 is blown, the BE junction is open circuit both directions. The resistance between the BE terminals is about 430 ohm (transistor out )
The bad news is I have replaced the transistor and there is still no volts across the motor, the motor is not open circuit.
Any clues on where to go from here, apart from binning the welder!
