I need some help anyone i have a migatronic 160 mig welder and it seem to work for 30 minutes and then it starts to play up the wire sounds like it is jamming up and it cuts the gas off the welder set up is correct and i am using 0.8mm wire i have used 2 torches and the liners are fine also the roller wheel for the wire is on 0.8 i dont know if anyone has had this problem before but any help would be appreciated thank you
not really sure about this one , just a thought , are you using your welders ampage more than 3/4 if so that could trigger it to run out of synk. as i said just a thought.
