Afoster61520
- Northern ireland
I can vouch for the R-Tech 250 mig. Weld 10mm steel easily for me single pass. I’ve fixed multiple 8-12mm JCB/FORD digger buckets seeing heavy work everyday. No issues yet.
Im running It on its own 16amp circuit off a 32amp sub board fed from main Db. Although it can be run from 32amp. But I found mine works well and gets more than enough power from the 16amp supply without causing any issues with supply.
very easily turned portable as it’s a light enough machine. Also with MMA function.
