Brian Armagh
New Member
- Ireland
I’m currently using 1.0mm x 8 mm BOC HD contact tips but the wire seems to weld on the inside when using 200amps. Is there a difference in tips ? If so should I change them ?
YesAre you using 1mm wire, and a suitable torch liner?
When does the wire weld itself to the tip? During steady welding? When you let go of the trigger?I’m currently using 1.0mm x 8 mm BOC HD contact tips but the wire seems to weld on the inside when using 200amps. Is there a difference in tips ? If so should I change them ?
