Serviced a Clarke 100EN for a guy this morning. It had been sat gathering dust in his garage for years & he just wanted it checking through, made safe & made to work. Usual problems through neglect (or ignorance) & just being stood for ages; main problem, Torch Lining. The standard black PVC type which had probably not been changed since new; wire spitting & farting & shooting back to the copper tip.
So, stripped the torch down to fit a new liner, upgrading to a heavier duty steel type, which last much longer. Liners (PVC or Steel) can be a bit of a pain to fit in direct, wired torches. You have to try & push it down the length of the cable (from the gun end) & it gets a little crowded in there with the gas hose & power cable. So, top tips:-
Keep the lead as straight as possible
Try not to kink the new liner when feeding it through; if it hits a dead end, stop pushing, & twist the outer sheating in your hands, freeing up all the cables inside.
Best one, rub some Fairy liquid on the new liner before you feed it in - works a treat!
Oh, and before you feed the wire through your newly fitted Liner, straighten the first 2-3 inches & FILE the burrs off the end (that prevents it from feeding smoothly all the way through the lead but snagging when it gets to the torch neck).
weldequip
weldequip
