MIG for 1/8 aluminium ...pulsed?
  1. smashweld Member
    514
    Central Scotland
    looked in to this a bit last year...wondering if there's much changed in 18 months....
    main use would be welding 1/8 shs/rhs frames....
    it wouldn't get daily/heavy use but could sometimes be in use most of the day
    what are the options?
  2. Hood
    Hood Forum Supporter
    7,915
    Carnoustie, Scotland
    Do you have 3 phase?
  3. smashweld Member
    514
    Central Scotland
    yes, not in the workshop yet but will be in the near future...3x100 cutoffs
  4. Hood
    7,915
    Your choices are wider in that case.
    The options are more or less as before although there are a few Chinese pulse Migs available now, how good or bad they are regards longevity I have no idea although Warrior give you 5 years on theirs, you pay a hefty price for that however.
    An EWM Pico may work for you seeing as you will just be doing 3mm and although you say you may use it some days for most of the day I suspect it will not really be continuous seeing as it seems to be sections rather than sheet.
    Other options are something like @HughF has, a Paton then of course there is the Oxford from TecArc. I have tried out the Cebora Pocket Pulse, it was very nice but let down with the 2 roll wire feed which meant a 3m torch was the limit and even then care was required.
    I am not sure about the Paton but most of the lower end pulse migs are fairly basic and do not have things like Hot Start and Crater Fill, these are two things that are of immense benefit for Aluminium welding. To get these features you really need to start looking at the likes of the EWM Phoenix or the various Lorch Pulse Migs but they are in a different price bracket and rightly so.
  5. smashweld Member
    514
    Central Scotland
    just remembering...you have/had the Tecarc spool gun? how would you rate that vs the Pocket Pulse or others you've tried around £2k? ish
    the higher end stuff is OTT for me unfortunately, maybe one day :D
  6. Jim Davey
    Jim Davey RH Davey Welding Supplies
    5,263
    Southampton
    How about a used EWM?
  7. Hood
    7,915
    I have only tried the Pocket Pulse or the EWM Phoenix pulse Migs, well there was another but....
    Anyway all of them were much much superior to the standard Mig with a spool gun especially when doing positional welds.
    The pocket pulse, as I said, was limited to a short torch due to the 2 roller wire feed and if not careful you would still get birds nests. Sadly it wasn't capable of using a push pull gun and I think that is really the case for all of the lower end ones.
  8. Hood
    7,915
    That is the way I went and I have often thought about selling the 330 but I just can't bring myself to do it :D
  9. Hood
    7,915
    BTW @smashweld you are more than welcome to take a trip North and give the Phoenix 330 and 355 a try out to see what you are missing :D
  10. smashweld Member
    514
    Central Scotland
    Cheers Hood... I'll keep that in mind...the EWM prices scare me tho :D
    £2k-ish is a bit shy for the (used) higher end machines?
  11. Hood
    7,915
    I don't know what Jim has in mind, I assume he has one but only he can say what he wants for it. . I can't recall exactly but I think, without the Push-Pull, I may have been around about that kind of money for the 330.
  12. henry Kadzielski Member
    720
    Australia Wollongong
    EWM, that's not scary, you should try Fronius:o. I should know I have two now, though the second one was aquired second hand from some one that was closing up. Still secondhand it was the cost of some new machinery
    smashweld and Hood like this.
  13. HughF
    HughF Member
    5,093
    Work: Dorchester, Workshop: Corfe Castle, Wife's place: Frome
    The Paton does not have hot start/crater fill. I'm trying to convince the factory to add a 4t mode to the psi-250p so it would do these two things.
    Another thing worth looking at are the pulse machines from various Italian manufacturers. INE, Selco, Helvi, Fimer, the cebora 2205dp or whatever it is called now.
    All the Italian manufacturers make something with pulse.
    smashweld likes this.
  14. smashweld Member
    514
    Central Scotland
    Is pulse the main thing for aluminium then? What thickness of metal could you go down to with MIG?
    I looked at MIG for alu a bit last year but was set on getting a TIG really so didn’t look in to MIG too much (or I just can’t remember!)
  15. Hood
    7,915
    I have done 1mm with pulse Mig as a test and it was reasonable for a first (and only so far) test.
    https://www.mig-welding.co.uk/forum/threads/mig-like-tig-or-almost-anyway.74184/
    Standard Mig for Alu should ideally be spray transfer so 3mm is really a min for it and 4mm is the min I would be happy doing in standard Mig. That is sheet however, doing tube sections was different as you are doing short runs with that and thus heat input isn't the same.
    smashweld and Richard. like this.
  16. smashweld Member
    514
    Central Scotland
    About £3-4K for a used machine going wi the posts in that thread
    But yeah when I had the SGS250 spool gun on our old 250 kemppi It was borderline too fast/hot but doable On 3.2 alu box.....couldn’t really see what was going on when welding tho, had to listen to the sound!
  17. Hood
    7,915
    Depends, as said mine was not as much, probably the £3k with the push-pull and VAT but it was however a 10yr old machine even though it had only had 22hrs arc time.
    Give Jim a PM and see what he has to offer.
  18. smashweld Member
    514
    Central Scotland
    Will do, got a job on just now that needs finished/paid before I”d be buying anything tho
    What’s the standard/max length for push pull? Did u opt for that because of the amount of welding you do/less time changing reels?
  19. Hood
    7,915
    I opted for the push-pull because the EWM does not support a spool gun, in fact I don't think any of the pulse migs really support a spool gun.
    A lot of pulse migs don't even support push-pull, certainly most of the lower end ones don't. I was at one time contemplating a Jasic 350P, it seemed to tick a lot of boxes but I had noticed there was no socket for a gun and it turned out that it was not capable of using one so that got knocked on the head as a push-pull is a must for the stuff I do.
    In fact there is actually a Jasic 350P on eBay at the moment, they look to be decent enough machines from the videos I have seen but.....
  20. Hood
    7,915
    Oh and standard length is 8m for a push-pull.
    For me even the 8m was a bit limiting so that is why I now also have the Phoenix 355 that I bought new. It has a separate wire feed unit and I got a 10m interconnect so now I can drive up to a boat, leave the base unit in the car and take the wire feed to the edge of the pier or onto the boat and then I have the 8m push-pull reach from there.
    Also the big spools is a definite plus point, they are cheaper and obviously I am not having to swap out reels every half hour.
Advertisements
