Robbie260
I fix things that others have broken
- Scotland highland
Hi all after quite a while now this is a long story have a customers automatic Vito that’s having issues with the auto box. I’ll start at the beginning.
It wasn’t coming out of park unless the emergency release was pressed, was staying in park on the dash was engaging reverse and reversing went into neutral, then would go into drive and be either stuck in first gear or not want to drive at all (it be trying too but not managing you could push the van and there be almost no weight too it but it wouldn’t manage to move forward under its own steam).
Plug in the diagnostics and it comes up with a C404 error code ( signal selector lever position) and P1856 ( selector lever position detection has failed).
Take the dash apart and removed the selector sensor module with ribbon attached the ribbon looked chaffed through and burnt at a point so assumed the ribbon had shorted on something and fried the circuit board. This part is no longer made by Mercedes but the owner managed to source a second hand one with matching codes.
It was installed and there was no change. Later I found a magnet off the bottom of the selector lever floating around inside the selector lever housing which had come adrift and I glued this back in place. Things improved slightly. The vehicle on the first try now comes out park and when you start reversing displays reverse on the dash with the new selector sensor module but will stay displaying reverse if you select neutral or drive and will still be stuck in first gear and when returned to park still displays reverse on the dash so unless the car is turned on and off again it won’t come out of park again without pushing the emergency release. With the old sensor module the original fault remains.
I have resistance tested the wiring and that all appears to check out.
I have sent the gearbox ECU and both selector sensor modules to ECU testing and they were returned saying they couldn’t test them.
The owner found a spare gearbox ECU on eBay with the same part numbers so we tried installing the originals and then taking a program copy of their details then programming in the new selector sensor module and ECU in that has made no difference.
Have even tried running a magnet over the sensor pickups myself unsure if this would work but thought it was worth a try and that doesn’t change the position displayed on the dash.
Anyone have any suggestions or encountered similar problem before?
