Good point worth checking firstAcetone will dissolve some plastics including ABS, which is a populate case material
Acetone is used to remove silicone from moulds iirc
].Isopropyl is my first choice for cleaning for this reasonProbably rubber or metal? Most plastics don't seem to like it [don't ask....].
I've never used it, but perhaps something like this would be suitable?
For discussion: most bathroom-type silicones are acetoxy-cure, based on acetic acid, hence the vinegar smell. Therefore most silicone dissolvers are likely suited to that chemistry.
I suspect that the silicones used in electronics are not acetic acid based as it seems to me that acid around electronic stuff might not be a good thing.
