greyshirtguy
Persistent Learner
Disclaimer: "Ok, as well as enjoying all things DIY (esp metal work) I'm a also computer nerd and try-hard hardware hacker (eg I love the kind of things you find on www.hackaday.com)"
Having learned how important a stable wire-feed is for successful MIG welding (This is a great site, Malcolm) - I felt curious to measure "how good is my little hobby MIG welders' wire-feed?"
After a little brainstorming I came up with a quick method so my laptop could measure and record it (to an accuracy of approx 4mm):
It's a bit hard to see in the first pic, so take a closer look:
Notice the grey thing in there, with the grey cable coming out of it?
Yep, it's an old USB computer mouse!
After some tinkering and improvising, I found a way to mount a (slightly dis-assembled) mouse so that the wire feed roller movement would be captured by the scroll wheel on the mouse.
I then wrote a (quick and dirty) .NET application to record the mouse wheel movements (18 "pulses" are captured per revolution of the mouse wheel)
I then ran a steel rule carefully over the wheel to record how many pulses in 600mm - which gave a (probably not too) rough calibration.
Now that it was mounted, talking to the PC and calibrated I was ready to record my wire feeder and make some pretty charts in Excel.
Any deviations in wire feed speed would show up most clearly in a chart (instead of a nice straight line - it would have curves/bumps in it).
So I did 10 quick test welds on some 1.2mm mild steel with various power and wire-feed settings and charted the wire-feed over the whole experience. I was glad to see what were acceptably straight lines (indicating a stable feed rate during each weld)
The vertical axis is metres of wire (wow! It didn't take very long to use up 8 metres of MIG wire
). The horizontal axis is time (in seconds). Each of the 10 test welds shows up as an upward sloping line with a (flat-line) pause in between. Weld 9 shows the adjustment in wirespeed made during it.
A close up of one weld shows the stability of the wire feed more clearly:
In some other tests not shown in this chart, I did notice that some really low speeds were not as stable on the higher voltage settings (thankfully they were way too slow to be used at those settings)
I understand most people might not see the "sense" in this project - but it was (for me) a really fun night, and I think I will do some more accurate calibrating and some more recording when welding again.
). The horizontal axis is time (in seconds). Each of the 10 test welds shows up as an upward sloping line with a (flat-line) pause in between. Weld 9 shows the adjustment in wirespeed made during it.A close up of one weld shows the stability of the wire feed more clearly:
