Over the years (often when i've been swapping the chuck on the lathe) i have wondered how you can manufacture the register into the back of the chuck to fit the conical upstand on the spindle-nose.
Say i wanted to produce my own face plate or the like, how would i measue the 'nose and get some measurements?
My first instinct is that i could use two peices of ground bar on opposite sides of the cone, that sit tangentially to the cone and also the face (at the base of the cone), then i magically sprout 6 arms to hold this against the spindle-nose and i could somehow mic. across the outside of the bars to give me a value.
Next, cut the conical pocket undersize in the blank material, use a pair of ball bearings the same diameter as the bar, hold these on opposite sides of this pocket and somehow measure the distance between these (6 arms again), account for the dia of the ball/bar and this would tell me how much meat is left to take off.
Does this sound feasable, or even make any sence?
Is there a standard way to do this in industry?
Cheers
Nathan
Cheers
Nathan
