NotANormalCoder
Retired fixer of welders
- Surbiton - Surrey -UK
Al
You are welcome. The old Max Arc was a good solid machine and will probably last years yet but probably will need a new contactor sometime as the Arrow unit fitted tended to burn out the contact as you have found.
I personally would use 0.8mm wire for your rollcage as it'll give you more control. If you want to use 1.0mm, try it on the existing rollers first and you may find it works fine.
Yes Woodfield Welding Services is me.
Dave
Dave
) I suspected these speed controls would not do the job, but they were ridiculously cheap, and enabled me to prove the rest of the machine was ok. after I had done that, I bought one of these
