Can anyone help me with this little problem?
I have been trying to use a gas lens but it seems to be causing problems for my masks (I have the same problem occurring with two different makes of auto-darkening filter).
The problem is that when running a weld, the filters intermittently switch from dark to light and back again, this happens for random lengths of time, (as though the weld current isn’t quite enough to switch the filter on).
This ONLY happens when I fit the gas lens, if I leave the weld current the same and swap the gas lens for the ordinary collet, everything is OK…
It occurred to me that I may need to adjust the Argon flow rate with the gas lens, I usually run about 8 litres / min, which is about 17 cu.ft / hr…?
Please help, as my eyes are getting a bit sore.
Thanks in advance.
Thanks in advance.
