CRB
You can call a millennium a kiloyear if you want to, I don't know how many others will follow but I certainly will.Whilst you are all at it, what about a millennium as in a thousand years not a million years?![]()
Because SI prefixes relate to metric units, not imperial. Imperial units are based on the length of three barley corns, you can expect them to be backwardsOddly though 1,000lb isn't a Kilopound, it's a kip.
.All you need is the angle of the flat plane on which the elipse will be formed and the diameter of the pipe, a bit of trig will give you the large measurement or you could just use a set of calipers at the same angle as the pipe passes through the plane much easier.Great video - I like that a lot.
How do you I know the larger measurement though? The smaller one is obviously the diameter of the pipe, but where do you get the larger one from?
