ajlelectronics
- Gloucester, England
The 25044 is the same stuff according to their data sheet (just different langauge on the packaging?) and is cheaper and quicker to get:
I'm obliged. Ordered for tomorrow.
i got one for a tennerBig late now but if you see a Wanner grease gun going cheap , give one a go . Little one handed jobbies are normally less than £5 at car boots/auto jumbles .
Thats interesting. Looks identical, apart from the rubber handle grip, to the one supplied back in the day, by Ford Tractor Operations Europe .If you want the best then alemite. Closely followed by mcnaught. They are expensive but work better in every way. The alemite pistol grip has 2 settings. High volume low pressure and high pressure low volume. Means you don't need a leaver type as well.
Alemite are the OEM manufacturer for CAT grease guns and mcnaught for John Deere.
This is currently on eBay. I would have bought it but it's listed as collection only.
I bought a Wanner 315 which works for oil as well, and is used just for this purpose - Triumphs need oil in the trunnions, but many owners mistakenly use grease which ends up at the top of the joint and the bottom wears out!Thank you Mat, that's helpful. I can use it for my car's trunnions too, if need be.
I have got two. Had them 30 odd years. The only grease guns I ever found that actually worked, and still do.
Blimey, I can hear your anorak rustling from here !A quick Google says alemite have produced grease guns for both ford, new Holland and case new Holland. But so have a company called Dearborn, by the looks these are highly collectable and are worth 2-3 hundred dollars in the states.
If you have never changed the chuck you can tell an alemite as they only have 3 jaws where as everyone else uses 4. The alemite chucks are infinitely better than anything else, even the g coupler type. And only usually a few quid.
Blimey, I can hear your anorak rustling from here !Dearborn was the home of Ford muscle cars back in the day, so makes sense.
But yes both mine have three jaw couplings, and they just, work. One has the flexible hose, and the other the steel tube. As you say, this is better !
